Zaxwerks Problem - Need Help
COW Forums : Zaxwerks
Image Reign
on Jul 26, 2007 at 4:48:10 am
I am trying to install my 3d invigirator pro plug in to my After Affects CS3. When I put my serial number in it says "Your permanant authorization code has been accepted". Then I get an error message saying " Invalid Zaxwerks Preferences folder- cannot open security file. Program will be cancelled."
I tried changing my files from read only it doesn't work. I don't know if this is a Windows Vista Problem or a Zaxwerks Problem.
Can Some one please help?
Matt Rhodes
Re: Zaxwerks Problem - Need Help
on Jul 26, 2007 at 4:37:28 pm
Hey IR.
It sounds like a Zaxwerks problem on Vista.
Can you email me offline (matt@zaxwerks.com) so
that I can ask you a few questions?
Once we figure out the issue, I'll post a note in the forums.
Thanks a lot.
Matt Rhodes
Zaxwerks, Inc.
DCDave
on Sep 24, 2007 at 2:51:08 pm
I have this same problem. I'm using Vista Ultimate X64 with AE CS3. However, when I install Invigorator Pro 4.3 on AE 6.5, which is also installed on the same machine, it works. Wonder if this is a problem with CS3 instead of Vista
