Selecting objects
COW Forums : Zaxwerks
Varangian
Selecting objects
on Jul 24, 2007 at 6:19:57 pm
i used Invigorator Pro version 4.0.4 to model an illustrator file.
When I go optins and launch the 3D Invigorator Set-Uo Window
I cannot see or select my object it the window.
Any way to fix this, or selct the object without seeing it (key command?)
thx!
Varangian
Re: Selecting objects
on Jul 24, 2007 at 6:33:22 pm
btw, the window is just white, no wireframe floor or objects as there should be.
Jon Okerstrom
on Jul 25, 2007 at 12:47:54 am
Hi Varangian,
I would suggest upgrading to the current version, which I believe is 4.1. Check out the support section of http://www.zaxwerks.com.
Jon
