Zaxwerks 3D Invigorator AE plugin not importing .ai log
COW Forums : Zaxwerks
vdubplate
on Jul 5, 2007 at 8:30:31 pm
I really need some help, I am on a project deadline.
I am using AE 7, Illustrator CS3, and Zaxwerks 3D Invigorator AE plugin.
I can not import a basic .ai file into my Zaxwerks 3D Invigorator software. When I import I get a message that reads, "There were no usable vector paths in this file."
Does anyone have this problem? I have already tried saving my .ai file as CS1 an CS2. Still no good.
Please help!
John.
JOHN D.
serge
Re: Zaxwerks 3D Invigorator AE plugin not importing .ai log
on Jul 5, 2007 at 10:23:59 pm
Make sure that the "use Compression" box is not checked when saving your file.
let us know if this doesn't help. You could then send me your file here: serge_01 (at) (msn) (dot) (com)
Salut.
Serge
INVIGORATOR-TRAINING VOL.1 soon available here: http://www.nyc-visual.com
vdubplate
on Jul 6, 2007 at 1:22:51 am
At the moment my logo is just a circle I made in Illustrator to see if I can extrude. I can't even do that. I still get the same error message. I can use all the other functions but importing an illustrator file just wont work.
JOHN D.
serge
on Jul 6, 2007 at 2:38:01 am
Did you do what I already suggested?
Did you give a fill color to your object in IL or at least a stroke?
Without seeing your file I can't really say what you did wrong.
Salut.
Serge
vdubplate
on Jul 6, 2007 at 2:53:00 am
It's just a circle with a stroke. I think it's my software. Because if I have just a circle with a stroke and I can't import that then there is something wrong.
JOHN D.
Jon Okerstrom
on Jul 6, 2007 at 3:35:03 am
John,
Which version number of Invigorator are you using?
Jon
vdubplate
on Jul 6, 2007 at 10:50:19 am
I'm running AE7 on a G4 powerbook with Zaxwerks 3D Invigorator Pro 4.09.
I did a test where I saved down to every version of Illustrator on my computer and I can only seem to open a illustrator file if it is saved to version 10 even with all check boxes unchecked in the save dialog box
(I left .pdf checked)
So problem is solved, now I just have to figure out how to use that function :)
Thanks for the help and the super quick response.
John.
