Animate Opacity of Individual Objects?
COW Forums : Zaxwerks
cosm44
on Jun 28, 2007 at 9:35:13 pm
Hi everyone...this is a very beginner question, but I've searched the manual and forum posts and have come up empty handed. Here's what I want to do:
I have a solid with 2 Invigorator objects on it. I want to fade one of these out as they animate, and leave the other at 100% opacity. I've tried layer mapping to the transparency setting of the object I want inside the material setup...yet it still doesn't work. And yes, I do have the layer mapping set to my transparency map layer.
Any help would be appreciated!
cowcowcowcow
Jon Okerstrom
Re: Animate Opacity of Individual Objects?
on Jun 29, 2007 at 1:17:06 am
Hi cosm44,
What about your technique doesn't work?
Create a layer on which the grayscale color animates from white (opaque) to black (transparent). Put that layer in a precomp. Designate that precomp as a layermap in Invigorator. Apply the layermap to the transparency channel of a material. Apply that material to the object.
That should work. Did you - or I - miss a step?
Jon
cosm44
on Jun 29, 2007 at 1:47:12 pm
Hey Jon,
If I remember correctly I've done everything exactly how you've stated. I'm at work right now so I don't have the project available. Once I get back home I'll check it out and if it still doesn't work maybe I can provide a link to it and you can take a look?
Thanks for the help.
Jon Okerstrom
on Jun 30, 2007 at 12:27:55 am
Sure. I'd be happy to look at it. I only need the AE project file, no supporting files.
Jon
