Control An Invigorator With a Null
COW Forums : Zaxwerks
PRgraphist
on Jun 28, 2007 at 12:44:18 am
How I can Control an invig object with a null. I try o pickwhip but it not working properly.
"I post that in AE expresion forum, but nobodie answer"
Serge
Re: Control An Invigorator With a Null
on Jun 28, 2007 at 1:59:05 am
If you have the Pro version of Invigorator you could use the Track 3D layer feature.
If you are using the classic version or an old pro version all you need to do is to create a 3D null layer and pickwhip each rotation and position parameter of your set to the null's. To reset your object, make sure you are in camera mode then click on "Front" in the view menu.
Does this help?
Salut.
Serge
INVIGORATOR-TRAINING VOL.1 soon available here: http://www.nyc-visual.com
PRgraphist
on Jun 28, 2007 at 8:59:01 pm
The track Layer method funtion (I forgot this feature), thanks. But the pickwhip not funtion because the defoult value of invig for positions is 0, when you pickwhip the expression to a null position it move in oposite way.
Serge
on Jun 28, 2007 at 10:03:58 pm
Did you reset the camera? If you still are having the object goind in the opposite direction a minus sign (-) at the start of the expression would eliminate the problem.
But I would advise you anyway to stick to the track layer feature.
Salut.
Serge
Ultimate Bart
on Jun 29, 2007 at 9:18:57 am
heey
here are great tutorials for zaxwerk. also with null objects and stuff (3D object tracking part 1 and 2)
http://www.motionworks.com.au/tutorials/tutorials_01.htm
Bart
