Stretching the scene preview window
COW Forums : Zaxwerks
paddyjitters
on Jun 25, 2007 at 6:00:40 pm
My scene preview window will not give me the option to expand it. The window is cropped and it doesnt have the tab on the bottom right, like most windows, to allow me to stretch the whole workflow window, Does anyone know how I can get it to the proper size so I can actually see the work. Thanks for any help!
Patrick
Matt Rhodes
Re: Stretching the scene preview window
on Jun 28, 2007 at 12:46:41 pm
Hi Patrick.
You may need to delete your preferences and try again.
There are two locations where the prefs may exist:
1. In the same folder as your plug-in (inside the After Effects Plug-ins folder)
2. On the Mac, inside your local Preferences folder (~/Library/Preferences)
Once you find the file, rename the preferences file to some other name.
The Invigorator Prefs file is called "Zaxwerks Invigorator Prefs".
The ProAnimator Prefs file is called "Zaxwerks ProAnimator Prefs".
Once you've renamed the prefs file, try loading your scene again.
Let us know if you have more questions.
Matt Rhodes
Zaxwerks, Inc.
Paddyjitters
on Jul 5, 2007 at 4:00:08 pm
That worked, Thank you so much!
Patrick
