Exporting 3D model from Pro Animator
COW Forums : Zaxwerks
Ken Latman
on Jun 22, 2007 at 8:24:38 pm
I'm doing some experimenting here. With the new Photoshop CS3 Extendend verision you can bring in 3D objects into a docuement.
It will take .obj files and .3ds files that Pro Animator can export.
Why can I not see anything with a .3ds file?
The .obj file works great but my color and textures do not come over. Can this be accomplished in the .3ds file and how can I get it to work?
maplesyrup
Re: Exporting 3D model from Pro Animator
on Nov 4, 2007 at 10:23:12 pm
Howdy,
Yes... this is exactly what I would like to know also.
Additionally, if you can does this in Photoshop CS3.. why not AE?
Regards
Mike
maplesyrup
on Nov 4, 2007 at 10:40:45 pm
Ken,
Did you find an answer on this?
Mike
Jon Okerstrom
on Nov 5, 2007 at 12:45:37 am
Hi guys,
A couple of thoughts on this - first, people in other forums report issues with Photoshop's 3D import function. I read one post indicating graphics card choice can have an impact on this but it's not confirmed.
The other thought - Invigorator and ProAnimator use a unique method of applying multiple textures on a single object. (Splitting bevel and sides with the materials editor.) These materials or textures will not be exported with your .obj object. Instead, you'll get the object in its default color.
Do a simple test. Export your elements from ProAnimator, then import them into an empty scene. If that works (and it should) the problem is likely Photoshop 3.
Does this help?
Jon
maplesyrup
on Nov 5, 2007 at 7:45:30 am
Hi there,
The export - import out of ProAnimator works fine.
I assume that the .zxa save file contains both the project and the materials used.
The file missing from the .obj is a seperate .mtl file. So the question is... is there a way to get an .mtl file out of Zaxwerks?? or am I SOL :)
Mike
