3D warps; Filmstrip Warp in 3D space tutorial????
COW Forums : Zaxwerks
tbmotion
on Jun 16, 2007 at 11:28:38 pm
Hi folks,
just purchased 3D warps with the intention of using it to warp an animated filmstrip coming into view from the bottom of the screen, and moving back into z space. I'm reading the manual, and just thought I'd see if anyone has done this already.
As an example, I'm looking to do something more like Chris Bobotis project using Forge FreeForm. Can you do this in 3D Warps??? and how? http://www.creativecow.net/articles/bobotis_chris/filmstrip/moooovie.mov
Thanks for the tips.
Julian06
Re: 3D warps; Filmstrip Warp in 3D space tutorial????
on Jun 17, 2007 at 6:20:42 am
Hi
when i look at Jon's example of 3d Warp here
http://forums.creativecow.net/cgi-bin/new_page_wrapper.cgi?forumid=41&page=...
i guess it is possible.I like this one here most
Maybe Jon will tell us more about the Filmstrip Follows Warp example
Jon Okerstrom
on Jun 19, 2007 at 1:00:14 am
Hi tbmotion,
The filmstrip animations are actually fairly simple. I created the strip (with empty frames) in Illustrator, each frame can be filled with a still image or a movie. Put all of that into a precomp that's the size of the strip itself... really wide and short, in my case.
Now apply the 3D Warp effect to another layer and use the first precomp as the colormap.
Let me know if you get stuck and I can go into more detail.
Jon
TBMOTION
on Jun 21, 2007 at 12:02:13 am
THANKS JON,
I DID FIGURE IT OUT AFTER I STARTED USING IT WITH 3D INVIGORATOR IN MIND. I USED THE COLOR MAP FEATURE AND ALL IS WORKING PRETTY GOOD. I WOULD PREFER THAT THEY CHANGE SOME OF THE CONTROLS TO INCLUDE BEZIER HANDLES AND CENTER POINTS, INSTEAD OF JUST NUMBER REFERENCES.
-TIM
richieb
on Jul 5, 2007 at 3:43:14 pm
Jon,
If you don't mind, could you send me your .aep project file for the filmStrip project so that I can see how you created that sequence? I was trying to follow your instructions, but I am not getting it to work.
I must make known that I am relatively new to After Effects.
Thanks.
