Zaxwerks w/ Illustrator file
COW Forums : Zaxwerks
stevem1928
on Jun 15, 2007 at 6:30:11 am
I am having trouble using an .ai file in ProAnimator. Everytime I open the .ai file in Zax it shows a solid rectangle with the logo cut out, as if it was a negative. I am not well versed in Illustrator or Zax. I am trying to help someone else out with this. I have downcoverted the .ai file to ai 8 and turning on "open by layers", "Use Ill colors", & "move obj to center". I think the problem lies in how I created the LIVE TRACE of the logo. Any ideas?
Serge
Re: Zaxwerks w/ Illustrator file
on Jun 15, 2007 at 6:58:25 am
Hi Stevem1928,
Tracing a logo using the pentool etc... is often more efficient then using the live trace features as you may end up having a bunch of unnecessary paths. Generally, your artwork must consist of simple closed shapes. Send me your file and I will trouble shoot it in the morning (It's 3:00 am in NY, so I gotta go sleep now)
serge_01(at)msn(dot)com
Salut.
Serge
"InvigoMany" On sale here:http://www.nyc-visual.com
stevem1928
on Jun 15, 2007 at 12:54:26 pm
I was reading one of your other posts where you did that for someone. I was not able to follow how you helped him. I won't be able to access the file until later today. Basically the logo is a very simple live trace of 7 letters. All of them are separate from each other, except for 2 letters touch just a bit and are joined together.
Matt Rhodes
on Jun 15, 2007 at 3:28:19 pm
Hi Steve.
If you can send me the file, I'd be happy to take a look.
Some Illustrator files just need a little massaging before
being brought into the Invigorator.
You can send the file to: matt@zaxwerks.com
Matt Rhodes
Zaxwerks, Inc.
stevem1928
on Jun 15, 2007 at 7:37:46 pm
Here is a link to a screen capture.
http://i122.photobucket.com/albums/o249/stevem1928/cleacapturer.jpg
The thing that drives me crazy about this is....I went th rough this 6 months ago, and finally figured it out through a bunch of searches. Now I can't find those same posts.
I will send the .ai files to each of you. Thanks.
Matt Rhodes
on Jun 15, 2007 at 8:02:13 pm
Hi Steve.
Your file had some extra elements in it, causing the problem.
Note that when using the Invigorator, it's not about how the AI file looks
on screen, it's about making sure that the only things in the file are the
outlines that you want imported. This is certainly part of the learning curve.
(hey, that's a pun!)
Let me know if you have any more questions.
Matt Rhodes
Zaxwerks, Inc.
stevem1928
on Jun 15, 2007 at 8:43:26 pm
I am going to paste your email response here to help others.
This is one of those files that looks simple, but has
a bunch of extra stuff in it that confuses the Invigorator.
Here's what I did:
- I Released the Compound Path
- I Released the Crop Marks
- I Ungrouped the objects
- I deleted all of extra elements that weren't necessary
(there were a lot of little duplicate objects)
Once I did that, I ended up with just the outlines for the letters,
and it imports correctly.
stevem1928
on Jun 17, 2007 at 10:31:07 pm
Thanks. We got it work.
