How to add moe Fonts to 3D Invigorator text?
COW Forums : Zaxwerks
Lord Scales
on Jun 4, 2007 at 1:11:55 am
Hi there!
I like creating 3D Text in Invigorator, but I have a font called Carta, available in the text tool of AFX, but not in the Invigorator's.
So, how can I add more fonts to text in Invigorator? Thanks a lot!
Jon Okerstrom
Re: How to add moe Fonts to 3D Invigorator text?
on Jun 4, 2007 at 11:37:06 pm
Hi Lord Scales,
If the fon't available in your sytem, you should be able to see it. If you have an issue with a particular font, you may want to send it to tech support so they can take a look.
The short-term solution, of course, is to convert the text to outlines in Illustrator. It'll behave the same as any other object then.
Jon
