Invig Prefs File
COW Forums : Zaxwerks
JezzFush
Invig Prefs File
on May 23, 2007 at 6:06:30 am
Hi, I keep getting this warning whenever I make changes in the Invigorator Pro setup window and exit. "unable to open zaxwerks invigorator prefs file for writing - settings may not be saved properly". I am working on a Mac G5 Power PC and running Invigorator Pro v4.0.9
It doesn't seem to be causing any problems, just annoying.
Any help would be appreciated. Cheers.
Matt Rhodes
Re: Invig Prefs File
on May 23, 2007 at 1:45:58 pm
Hi JezzFush.
It sounds like you don't have write access to either the Invigorator Pref file or the folder that the Invigorator Prefs file is in.
I would suggest doing the following:
1. Open the folder where you have the Invigorator installed.
(For AE 7, this is usually /Applications/Adobe After Effects 7.0/Plug-ins)
2. Click on the folder containing the Invigorator plug-in.
3. Press Cmd+I (Get Info).
4. Check your permissions at the bottom of the Info dialog box. Make sure you have "Read & Write" access to the folder.
If that looks correct, find the "Zaxwerks Invigorator Prefs" file in that same folder.
Follow steps 3 and 4 to ensure you can read and write the Prefs file.
Let us know if you have any questions.
Matt Rhodes
Zaxwerks, Inc.
Jon Okerstrom
on May 24, 2007 at 12:44:55 am
Hi JezzFush,
I would first suggest upgrading to the current version. 4.1.0 is available on the Zaxwerks website... it's a free update.
Jon
