3d Champagne Glass
COW Forums : Zaxwerks
Michael Wilfong
3d Champagne Glass
on May 9, 2007 at 6:55:23 pm
I remember seeing a tutorial long ago about creating wine/champagne glasses in Invigorator...can anyone point me in the right direction...Or if anyone has another suggestion, I'm all ears....Thanks in advance...
M.
Jon Okerstrom
Re: 3d Champagne Glass
on May 10, 2007 at 12:08:41 am
Michael,
It's easy using a custom edge and a very small Illustrator circle as the base object. I seem to remember some info on the Zaxwerks site - otherwise, search the archives. If I can dig up more specifics, I'll add a follow-up post.
Jon
serge
Found them!
on May 11, 2007 at 4:21:33 am
I don't know about a tut but here are some custom edges that you could download from here:
http://zaxwerks.com/goodies/custom_edges.shtml
I also have a champagne flute created for you here:
http://www.nyc-visual.com/Edge_Examples.sit
You need to replace the file with the one located in your Edge Examples subfolder then apply the edge named "Champagne_Flute".
If you want the glass to be full like in the following example: http://www.nyc-visual.com/Flute.mov do the following:
Apply the edge named "Liquid" to a second tinny circle in order to map it with a champagne color looking map then reduce this second object depth by one point.
Duplicating this second object, reducing its depth by one point and applying a bubbles map to it would help too.
Salut.
Serge
"InvigoMany" On sale here:http://www.nyc-visual.com
