comp lights
COW Forums : Zaxwerks
Mike Johnson
comp lights
on May 3, 2007 at 4:15:45 pm
For whatever reason, "use comp lights" is not behaving as i would expect it to. I have a simple comp, with 2 invig layers, one "floor" 3d solid, and 4 lights. i selected "use comp lights" in my invig layers. i do notice a difference, so it is accepting the lights. however, when i bring the lights' intensity down to zero ( i want to fade the lights up) my floor goes black, but my invig layers stays lit. is an opacity animation the only way to do this or am i missing something?
System 1: G5 2Ghz DP, 1.5 GB RAM, OS 10.3, FCP 4.1, QT 6.4, AE 6.0, 2 TB Xserve RAID through a Vixel 335 Fibre switch, DVCAM SDI a/v and BetaSP Component through AJA IO, NTSC monitor through Videotek VTM100 through IO
Second System: G4 1Ghz DP, 1 GB RA
Matt Rhodes
Re: comp lights
on May 3, 2007 at 5:33:12 pm
Hi Mike.
Would you mind sending my your project (.aep file only)?
I'd be happy to take a look. You may have found a bug.
Send files to:
matt@zaxwerks.com
Thanks a lot.
Matt Rhodes
Zaxwerks, Inc.
Mike Johnson
Re: comp lights
on May 3, 2007 at 6:19:10 pm
sent
