Invigorator Flicker
COW Forums : Zaxwerks
Dups303
Invigorator Flicker
on Apr 23, 2007 at 9:36:51 pm
I made 3d text with invig and everything looked great. I rendered out a comp and it was perfict. I want back and made a few changes and now when the text rotates to the left and right the color flickers. I don't know what changed but now the animation looks horrible. Any ideas would be great!
Thanks for you help.
Jon Okerstrom
Re: Invigorator Flicker
on Apr 24, 2007 at 12:12:28 am
Hi Dups303,
Are you using reflection maps?
Jon
Dups303
on Apr 24, 2007 at 5:27:21 pm
Im not sure. When I created the moving text I just opened a new layer and applied invigoratior. I typed in my text and applied a preset material style. I hope this helps. Where would I find out if I did this?
Matt Rhodes
on Apr 25, 2007 at 4:47:19 pm
Hi Dups303.
If you can email me your scene (.aep file) and let me
know where to look for the problem, I'd be happy to check out your project.
You can email files to: matt@zaxwerks.com
Thanks a lot.
Matt Rhodes
Zaxwerks, Inc.
Henry_B
on Oct 27, 2007 at 5:38:45 am
im having the same problem with flickering texts and i was wondering if you solved your problem??? just wanted to know how did you solved it?
it seem that reflecting materials and moving text is whats causing the problem, but not very sure about it.
thanks in advance.
Grace Gonzalez
on Aug 5, 2010 at 6:01:05 pm
It seems I'm also having the same issue, not only do i get the flicker with text but also with vector files I've brought into Invigorator. I'm pretty much getting this issue with any type of file. The flickering happens whenever the image is not in motion after it's finished whatever move I've applied to it. Some insight on this issue would be awesome.
