3D Flag - Looping Issue
COW Forums : Zaxwerks
Renjamin
on Apr 9, 2007 at 3:11:03 pm
Greetings, :)
I've recently purchased the After Effects, Zaxwerks 3D Flag.
I got a looping issue,
Basically, I'm trying to avoid is the Cutback that the last frame has to the first frame. Thus having the animation flowing into itself seamlessly. In the Effects Controls Preview, it works fine because the time is continuous.
I've also checked the User Manual, (unless I'm blind LOL) I couldn't dig up anything that helps the cause.
Any Suggestions?
Thank you kindly,
Ren. :)
Jon Okerstrom
Re: 3D Flag - Looping Issue
on Apr 10, 2007 at 12:01:09 am
Hi Ren,
Here's a recipe from Zax in the forum archives,
It's not exactly looping but will get you there.
Jon
..The 3D Flag plug-in is a completely physics-based cloth simulation, so you can't set exact start/stop keyframes. However, wind in this simulation is very very smooth, it doesn't suddenly dip or turn unless you tell it to. So if you set the wind speed to be constant the flag will fall into a rhythm. You can then render out a few seconds of the animation and find a decent looping point to do a crossfade and, viola!, you have a looping segment of video.
Here it is in steps. . .
1- Set up the flag.
2- Set the wind speed to 11.
3- Set Pre-roll to 8 (you want to make sure the flag is well into the simulation before you start to render)
4- Render out 10 seconds of animation.
5- Take the clip into an editing program.
6- Duplicate it and make the top layer partially transparent.
7- Slide the bottom copy back and forth in time, until you match up the wave patterns.
8- Set the transparency back to normal.
9- Do a short dissolve from one copy to the other at the match point. ("short" means something like half a second)
10- Render out the looping section of flag.
There you go!
-Zax
Renjamin
on Apr 13, 2007 at 2:44:39 pm
This is great. Got it working very smoothly, much appreciated.
