More help please..
COW Forums : Zaxwerks
henry199
More help please..
on Mar 26, 2007 at 2:35:18 am
I was kindly helped here.. http://forums.creativecow.net/readpost/41/857272?
Just a further question.
- I've done my edit (Text and Vide) in Comp A.
- I've done my rectangle spinning in Comp B.
- I've put Compa A in comp B, and have made comp A a lyer map.
- Why is my text gray and fuzzy - instead of white text and clear?
Thank you
Jon Okerstrom
Re: More help please..
on Mar 26, 2007 at 12:24:49 pm
Hi henry,
Be sure the precomp you're using as a layermap has enough resolution if you're zooming in close to the Invigorator object to which it's applied... you may need to increase the resolution - but keep the aspect ratio the same. Also be sure that you have chosen "best quality" for the precomp.
Jon
henry199
on Mar 27, 2007 at 5:03:17 am
Thanks Jon. Will check this out. Thank you!
