TV Tube
COW Forums : Zaxwerks
hig116
TV Tube
on Mar 23, 2007 at 3:47:14 pm
I am trying to create a TV tube from an old style television. It needs to be slightly round. I can't seem to figure out how to do it. I will be adding a layer map of video on it, so it has to be proportional as well. Any assistance would be greatly appreciated.
Keith
Jon Okerstrom
Re: TV Tube
on Mar 23, 2007 at 8:53:08 pm
Hi Keith,
Given the organic complexity of the shape, you'll probably have to build it in pieces.
I'd recommend using a rectangle 3x4 aspect ratio with a custom bevel for the front and a separate piece for the rear of the tube, again with a custom bevel. If Serge reads this, my bet is he'll take it as a challenge and try to build one. ;-)
Jon
hig116
Re: TV Tube
on Mar 23, 2007 at 9:07:48 pm
I really only need the front of the tube, because I will have it sit inside of the actually tv box. If that make any sense. I will keep playing with it and let you know how it turns out.
Keith
