Proanimator - Quicktime Mov Texture Map Length
COW Forums : Zaxwerks
mbloflin
on Mar 20, 2007 at 3:57:27 pm
Reading the PDF's for ver. 3 and 4 I did not see much mentioned about MOV textures (believe support was added in version 4 but it is not in the ver 4 Addendum). I made a MOV from the PunchyReflections targa so my edge highlights would keep sparkling. Looked great. But I need a longer version so I doubled the length and now it won't load properly or save properly in the AE Proanimator layer. Anybody know what the restrictions are for MOV textures? Size, length, codec, etc.
After reading here about using a Comp or Layer as a texture I may change it around to that technique but still curious about the movies.
Brad Loflin
Matt Rhodes
Re: Proanimator - Quicktime Mov Texture Map Length
on Mar 20, 2007 at 4:37:44 pm
Hi Brad.
I don't know of any limitation to the movie lengths, so
you may have found a bug.
Is there any way you can send me the movie file you're using?
And a project file?
I'd be happy to take a look.
Send files to: matt@zaxwerks.com
Thanks a lot.
Matt Rhodes
Zaxwerks, Inc.
