• | rotating text around a sphere in invigorator pro
on Mar 17, 2007 at 12:29:36 am |
I have invigorator pro and I've been asked to create a globe with text rotating around it like saturn rings. I understand there is a way to do this in invigorator that involves manually placing each letter around a primitive sphere...then turning off the sphere.
This seems like a very time consuming process for a text with lots of words.
Is there any easy way to do this
• | Re: rotating text around a sphere in invigorator pro on Mar 17, 2007 at 12:50:43 am |
Hi egeefay,
You might save some time by putting the text around a circular path in Illustrator, or by setting up the project using placeholders in Invig and using the reload or replace command in Invig depending on how you set up your Illustrator file.
To be totally truthful the simplest solution by far is ProAnimator.
Jon
• | Re: rotating text around a sphere in invigorator pro on Mar 20, 2007 at 2:49:29 pm |
When I try to lay out the letters along a circular path in illustrator I get an uneven looking sentence when I try to open the file in invigorator and rotate all the letters to stand up facing the viewer
http://www.egeefay.com/espublic/inivigorator1.jpg
The reason appears to be that the letters are not centered straight up and down when they are opened in invigorator but tend to want to lay diagonally
http://www.egeefay.com/espublic/invigorator.jpg
I tried straigtening out the letters one by one but it's not an easy fix.
Wonder if you had any suggestions to make it work
• | Re: rotating text around a sphere in invigorator pro on Nov 13, 2008 at 9:42:57 pm |
Howdy folks!
Sorry to bring this post back up, but there doesn't seem to be a resolution, and I have been asked to do this very thing.
I need to know how to do this in 3D Invigorator Pro. I am using it with After Effects 7.0 on a PC.
Geno A. Palazzari
Creative Services Commerical Producer
KAAL-TV
Rochester, MN
• | Re: rotating text around a sphere in invigorator pro on Aug 27, 2010 at 12:37:48 am |
I now have the same task. Did anyone find a resolution?
• | Re: rotating text around a sphere in invigorator pro on Aug 27, 2010 at 3:41:55 pm |
I received an email from Serge Hamad with an explanation, but unfortunatley, I have moved on to another employer and no longer have access to the email. Hopefully he will get to you, or you might try sending him a message. His solution worked.
Geno A. Palazzari
PEG Manager/Gillete Public Access
201 E. 5th St
PO Box 3003
Gillette, WY 82717
