making a crumble down the center of text
COW Forums : Zaxwerks
brngthepain13
on Mar 2, 2007 at 8:53:52 pm
i am doing a logo design and am having two dogs pulling on each side of the logo i am wanting the text to crack down the center giving the impression that the dogs are stressing and cracking the logo i was going to design the text in zaxwerks and then i wasnt sure how to do the crack any help is appreciated
Jon Okerstrom
Re: making a crumble down the center of text
on Mar 3, 2007 at 2:04:59 am
Hi brngthepain13,
How realistic do you want the cracks to be?
If you want to make the 3D logo actually appear to crack or break in two, you can use layer cycling... Go from the complete object to a small crack to a larger crack and even two separate parts over the course of the animation.
You can use layer cycling to make the logo stretch over time too... like it's elastic.
Short of doing that, you can use a layermap to introduce what look like cracks on the surface, without changing the geometry.
Does this help?
Jon
brngthepain13
on Mar 3, 2007 at 5:59:38 pm
this was a great help thank you very much
