Zaxwerks render help
COW Forums : Zaxwerks
ilegal31
on Feb 9, 2007 at 3:22:38 pm
Hello,
I had created a 3D text in Zaxwerks and exported as a Quicktime Animation to composite in After Effects, but the video looks bad, does not have detail, raged edges and it flares, I had used the following settings in Zaxwerks to render:
*Pixels: Square (1.0)
*Resolution: 720 by 480
*Render: Invigorator
*AntiAliasing: 5by5+1.5
Any advise please?
Thanks in advance.
Jon Okerstrom
Re: Zaxwerks render help
on Feb 9, 2007 at 7:11:23 pm
Hello.
Did you render fields or frames? (interlaced video can look bad on your computer - worse on a monitor if the field order is wrong). Check your import settings for field order, fps, etc.
Jon
ilegal31
on Feb 9, 2007 at 9:19:36 pm
Hello,
I had tried all the options, field order, full frame, pixel aspect ratio, everything, and still... no luck.
Any possible solution?
Thanks.
Matt Rhodes
on Feb 11, 2007 at 10:56:33 pm
Hello.
Would you mind sending me the file and giving
me instructions on how to replicate problem?
I'd be happy to take a look.
Send the file(s) to: matt@zaxwerks.com
Matt Rhodes
Zaxwerks, Inc.
