Puzzle's Maps Issue Resolve!.. Another litle problem
COW Forums : Zaxwerks
PRgraphist
on Feb 4, 2007 at 2:27:12 am
I already maped the puzzle, but I can make anything to desapear the Join lines of the puzzle. When the pieces are in final place, I can see a very thing line on the contour of each piece. How I can resolve it?
Serge
Re: Puzzle's Maps Issue Resolve!.. Another litle problem
on Feb 4, 2007 at 5:04:58 am
First, I would use the basic flat side outside edge. In case this still doesn't work, I would then create a plane, map it with the same movie and use an animated transparency layer map (Black to white).
The animation should only take a couple of frames to reveal the movie. Also, use the Absolute Color feature to map both the puzzle and plane. This should work if your puzzle animation is ending frontal.
Let us know if this works.
Salut.
Serge
"InvigoMany" On sale here:http://www.nyc-visual.com
PRgraphist
on Feb 4, 2007 at 2:52:38 pm
Explain a litle more, the part of the plane a and animated transparency. I already have the flat edge and abslute color material?
serge
Mini_tutorial
on Feb 5, 2007 at 12:23:45 am
Here is a basic tutorial for you:
http://www.nyc-visual.com/Puzzle_Tutorial.mov
Project:
http://www.nyc-visual.com/Puzzle_Tutorial.sit
Let us know if you need more help.
Salut.
Serge
