Very much a rookie question..what and where are set assignments ?
COW Forums : Zaxwerks
Josh J. Johnson
on Feb 2, 2007 at 8:45:17 pm
Thank you very much for any help.
Jon Okerstrom
Re: Very much a rookie question..what and where are set assignments ?
on Feb 3, 2007 at 1:44:21 am
You're talking about Invigorator, of course.
Click the red ball below the scene preview window. That brings up the set-up window. How, select one of the objects - either using a tool or by choosing it in the object menu. Look for a small numerical pop-up next to the object selector. Those numbers represent sets. Once you've assigned each object to the appropriate set, close the set-up window.
Then, look for the set selection popup below the scene preview window. Choose a given set and animate it. Do the same for the other sets.
I know this is very short and very fast, but does this help?
Jon
Josh J. Johnson
on Feb 5, 2007 at 5:18:07 pm
Thanks Jon!
