Tracking 3d objects in 3d layer - invigorator
COW Forums : Zaxwerks
JamesNiblick
on Jan 22, 2007 at 5:38:45 pm
the zaxwerks literature for 4.01 claims there is a switch to allow 3d objects in Zaxwerks to be tracked with a 3d layer in an after effects composition. where is this magic switch?
also, any idea where a list of the file formats Invigorator can import might be?
kurt murphy
Re: Tracking 3d objects in 3d layer - invigorator
on Jan 22, 2007 at 10:13:12 pm
Create either a Null layer or a Solid layer, turn on the 3D switch and animate the Null or Solid to your liking. Open up the Set that you wish to track and you'll see a "Set X Track 3D Layer." Assign the Null or Solid to this - it will attach itself to the Null or Solid and animate accordingly. If you use a Solid, just turn of the video eye.
Hope this helps,
kurt murphy
