How to freeze frame Invig Pro?
COW Forums : Zaxwerks
NavarroP
on Jan 19, 2007 at 4:12:21 pm
Is there anyway to get Invig Pro not to render every frame if there are no animated parameters? I notice that even if nothing is animated, Invig renders every frame (which leads to really long render times).
Right now, I'm rendering out a still, importing it and then replacing my Invig layer with it.
Is there a way to freeze the current view?
rremde
Re: How to freeze frame Invig Pro?
on Jan 19, 2007 at 6:47:20 pm
You could drag the out point of the scene (the red marker at the top of the timeline) so that the rendered movie is only a couple of frames long, render it as a pict or targa sequence, and only import the first image.... that might work.
