Texture map question
COW Forums : Zaxwerks
Budrick21
on Jan 18, 2007 at 9:00:00 pm
Haven't used Invigorator in a while and I'm running into an issue with texture mapping.
I have an image of Florida, and I need to zoom in fairly close, at which point the outline of a county draws on. If I open the Florida vector file (512x548 pixels) in Photoshop and use it as a texture map, it ends up getting scaled and looking very soft.
If I use a much bigger file, Invigorator scales it way down, and then when I zoom in it gets soft again. I thought I could get around this by using the Stroke effect and stroking a mask, but no luck.
Any advice?
Serge
Re: Texture map question
on Jan 19, 2007 at 1:16:36 am
First, your texture map must have the same aspect ratio then your object.
Second, create your map at the maximal resolution.
For example if your object aspect ratio is 2:1, create a map that is 4000 x 2000.
Keep in mind that the maximal resolution a map can have in order to work with Invigorator is 4000 x 4000.
Salut.
Serge
"InvigoMany" On sale here:http://www.nyc-visual.com
