Need Swatches In Correct Folders!
COW Forums : Zaxwerks
th3rdeye
on Jan 15, 2007 at 5:05:13 pm
Hi
Somehow my swatches for light, lighting style, material and object style swatches for Invigorator Pro 4 are all in one folder under Zaxwerks. I need to know which goes in which swatch folder. As you all may know the file extensions are ZXM, ZXS, ZXS, ZXI, ZXL, etc. Whenever i pull up my styles and materials, everything or nothing is in their like it should be on default. Please help. thanks.
Jon Okerstrom
Re: Need Swatches In Correct Folders!
on Jan 16, 2007 at 1:27:39 am
Hi th3rdeye,
Doing a clean install is the simplest, fastest way to correct this - you can save the old libraries you've made and add them to the standard libraries.
Jon
