creating and assigning objects to sets
COW Forums : Zaxwerks
eddiekay
on Jan 13, 2007 at 2:02:46 am
I have 2 (3ds) objects. I want to import them and assign one of them to SET1 and the other to SET2. How is this accomplished?
Jon Okerstrom
Re: creating and assigning objects to sets
on Jan 13, 2007 at 1:57:14 pm
Hi eddiekay,
Since you're talking about sets, I'm going to assume you're using one of the Invigorator apps.
Click the red ball to go to the set-up window.
Below the window choose the 3D block icon to get into the object mode.
Now, select the object in the window or in the object pop-up window.
Notice the smaller pop-up with the number in it? Choose the set number you want and hit okay.
You've now reassigned the object to another set.
Now you can select the different sets in the scene preview area and animate.
Hope this helps.
Jon
