invigorator motion path
COW Forums : Zaxwerks
Bill Triplett
on Dec 21, 2006 at 6:27:26 pm
How do I adjust the motion path in Invigorator?
Jon Okerstrom
Re: invigorator motion path
on Dec 22, 2006 at 4:01:07 am
Hi Bill,
What are you trying to accomplish? Invigorator uses keyframes to determine the locations of sets. Beyond that, you can edit the motion curves or use ease functions to smooth the path.
Does this help?
Jon
Bill Triplett
on Dec 22, 2006 at 4:24:07 am
Not seeing how to modify the motion curves.
Jon Okerstrom
on Dec 22, 2006 at 2:48:54 pm
Hi Bill,
You can edit the curves by twirling down the keyframes in the AE timeline. You're not actually editing the paths... you're adjusting the velocity and smoothness of the transition between the keyframes.
Jon
Zax Dow
on Dec 22, 2006 at 10:16:38 pm
An added note:
As an alternative you can use the 3D Layer Tracking feature.
That way you can see the motion path of an AE 3D layer and then tell an Invigorator object to follow that path.
-Zax
