Want to import Illustrator film WITH colors!
COW Forums : Zaxwerks
clintwood
on Dec 4, 2006 at 6:04:09 pm
I have Zaxwerks ProAnimator. I want to import an Adobe Illustrator file with colors, but even if the box is checked at the import dialog, all I got is an entire blue 3D-object. How can I map the original colors to that object?
thanks in advance!!
clintwood
Jon Okerstrom
Re: Want to import Illustrator film WITH colors!
on Dec 5, 2006 at 2:30:06 am
Hi Clintwood.
Here's my guess...
your largest object is blue. your other objects may be other colors, but they're not visible because they're all on the same Z plane. Try selecting your other objects and moving them forward in Z space. If you've checked the "use Illustrator colors" box, you should get those colors.
How's my guess?
Jon
One other thought - the "use Illustrator colors" option does not mean you can use fancy blends or patterns. You need solid Illustrator colors.
clintwood
on Dec 5, 2006 at 9:13:55 am
// How's my guess? //
Hi Jon
there were two problems. The first was, that the illustrator artist grouped everything together, so I couldn't seperate them in Zaxwerks.
So I asked him to delete the group now it works - AFTER I moved them forward in Z space :) So you were right, too. Thanks for the hint!
greez
clintwood
