How to make each letter to use its own set
COW Forums : Zaxwerks
dotan
on Nov 21, 2006 at 9:48:20 am
I searched the forum and tried to make each letter to have its own set but it didn"t work
this is what i tried:
I have this word "TEST"
in the setup window i press the second letter and choose set 2 the third letter set 3 and so on
but when i choose one of the letters its stay on the last set i"ve chosen for all the letters
what am i missing here?
thanx
Jon Okerstrom
Re: How to make each letter to use its own set
on Nov 21, 2006 at 6:55:02 pm
Hi dotan,
Assign the letters different set number as you have, then close the set-up window.
Now under the scene preview window, choose the set icon (three cubes). Now you should be able to select the sets containing individual letters.
Does this help?
Jon
dotan
on Nov 22, 2006 at 10:55:21 am
It still doesnt work
ill explain again what im doing
i have the text now i click on the second letter in the preview window and it turns red now i click the set 2 button and click the third letter that is now red and click set 3
after i click outside the word and then see if it works all the letters are at the last set i have chosen
is this the right way to choose the letters?
dotan
on Nov 22, 2006 at 10:58:09 am
I think i know whats the problem
when i click on a letter it turns red but the rest are still green
how can i click on just one letter?
thanx
Jon Okerstrom
on Nov 23, 2006 at 1:16:44 am
One way is to use the object pop-up menu below the set-up window. You can use it to choose one or more of your letters without actually clicking on them. You can also select invisible objects and deselect everything.
Jon
