Can't select object or material tabs in Invig Pro
COW Forums : Zaxwerks
Lars Bunch
on Nov 15, 2006 at 7:08:36 pm
When I click on the materials setup window button the window that pops up appears with it's tab selections UNDERNEATH the AE menu bar along the top of the screen. This means I am unable to select the object or materials tab or do much of anything in the setup window. Since I can't grab the gray bar at the top of the window, I can't move it to where I can access the tabs.
If I save and shut down AE, it will work fine the next time I start the program, but Invigorator Pro (4.08) will do this every time I create a new instance of the effect.
Is it possible that because I am using two monitors, that the plug in is getting confused? Is it possible to make it less confused without having to chuck my Cintiq in th trash?
Is there a simple fix for this?
My system is;
Dual 2Gig G5 w/ 3 Gig memory
OS-X 10.4.8
30" Apple Cinema Display
21" Wacom Cintiq Monitor
GeForce 6800 GT Graphics Card
AE 7.0
Invigorator Pro 4.08 Plugin
Thank you for any help you can offer,
Lars
