Exporting 3D Models from 3D Max to AFX
COW Forums : Zaxwerks
DCompositor
on Nov 14, 2006 at 7:08:21 pm
This is in regard to the best technique to accomplish the subject? When I created a model in 3D Max my intention was to bring it in AFX as and 3D model that
Jon Okerstrom
Re: Exporting 3D Models from 3D Max to AFX
on Nov 15, 2006 at 1:53:23 pm
DCompositor,
There are two possibilities:
If you render your 3D animation in Max, you'll want to be sure to save it in a lossless format that includes alpha channel. Quicktime animation) codec comes to mind.
You can import the model(s) into Invigorator and animate them there. However, the texturing abilities of Invigorator are not as robust as they are in Max. Invig does support UVmapping, but you'll have to break models apart by texture.
Does this help?
Jon
