My Set Up window is blank
COW Forums : Zaxwerks
EditDroid
on Nov 7, 2006 at 7:39:55 pm
In Invigorator Pro and AE 6.0 on a MacBook Pro 10.4.8 1.83 GHz 1GB RAM my setup window is blank. when I go into the set up to effect the text and add layer styles the window with in the tool is all white. Any thoughts on why this might be happening?
Jon Okerstrom
Re: My Set Up window is blank
on Nov 8, 2006 at 7:19:55 am
HI editdroid,
Are you saying your material and style libraries are blank?
Or are you saying the objects aren't visible in the set-up window?
Jon
EditDroid
on Nov 8, 2006 at 6:59:05 pm
Hi Jon,
I am saying the objects aren't visible in the set-up window. Sorry if I was unclear. Any ideas why this may be?
ED
Jon Okerstrom
on Nov 8, 2006 at 7:20:24 pm
Hi ed,
Try adjusting the camera view to "fit all". That should put every object in the set-up window in view. If it still doesn't, you may have turned off object visibility for the objects?
If you don't hit the camera icon below the scene preview window, you can use all sorts of views in the set-up window to view your objects.
Jon
EditDroid
on Nov 8, 2006 at 9:51:09 pm
Thanks for the input. Unfourtanetly the window is still all white. Any other thoughts I can't find anything online about this.
ED
Jon Okerstrom
on Nov 9, 2006 at 12:18:07 am
Send me the AE project file. No additional files needed.
jokerstrom1 (at) mac.com
Jon
pixelmeister
on Nov 12, 2006 at 2:44:35 pm
hi,
I had exactly the same issue. I could create an object, but the main preview window stayed blank.
When rendering, everything was there. I had that problem in both, the stand alone application
of ProAnimator AND the AE plugin.
Updating to ProAnimator 4.03 solved it (for me).
I'm running an Intel based Mac on OSX 10.4.8.
Hope that helps.
