Shadows on Glass Panels?
COW Forums : Zaxwerks
jim_wilson
on Oct 25, 2006 at 3:51:29 pm
Hello all,
I've got a couple INV objects with floating glass panels behind them and a couple of lights - all generated within an INV scene. I'm having difficulty having my objects cast shadows onto the glass panels. I've got cast shadows on for key and fill lights and I'm not using AE lights.
Any thoughts?
Thanks for any input.
Jim
Serge
Re: Shadows on Glass Panels?
on Oct 25, 2006 at 5:00:46 pm
Hi Jim,
Did you update your lights in the Scene Preview window?
Check also if your objects may not be too far from the transparent panels.
Another thing to consider is that if your panels are highly transparent the shadows will be too.
Therefore, to make your shadows appear less opaque you would need to add a reflection map to your panels. Avoid having a high shadow softness value and/or a low shadow darkness value.
Let us know if you still have problems.
Salut.
Serge
"InvigoMany" Available here:http://www.nyc-visual.com
jim_wilson
on Oct 25, 2006 at 8:00:33 pm
Thanks, I'll give it a shot.
Jim
