ProAnimator render has horizontal artifacts @ FILM rez
COW Forums : Zaxwerks
Richard Brooker
on Oct 24, 2006 at 10:56:28 pm
Greetings.
I am working in ProAnimator 4.0.2 to create silver-ish type with red bevelled edges. I used a default texture (#14 in Object Styles - blue/gray chrome with blue reflective edges - I changed the edges to red). FWIW my Machine is a G5 Powermac Quad running OSX 10.4.8.
The graphic was approved by the client (whew!) at video res. Now I am trying to rez it up for print use. Rendered at the highest res in ProAnimator "FILM" 4096 pixels wide, I am seeing thin random horizontal line artifacts on the faces of the type and also on the sides.
I am using the Invigorator renderer. I tried the OpenGL renderer, got cleaner results, except the type was all kind of squeezed into the lower left quadrant.
I hope I've been thorough enough in my desciption of the problem.
Has anyone seen this before? Any suggestions for getting a clean render at this higher rez?
Thanks and best wishes,
Richard Brooker
Matt Rhodes
Re: ProAnimator render has horizontal artifacts @ FILM rez
on Oct 25, 2006 at 12:22:53 am
Hi Richard.
Is there any chance you could post a screen shot of what you're seeing.
Also, is there any way you can send me a version of your project so that I can take a look
at the artifacts? There may be a rendering bug.
Thanks a lot.
Matt Rhodes
Zaxwerks, Inc.
Matt Rhodes
on Oct 25, 2006 at 12:24:28 am
You can send files to: matt@zaxwerks.com
Matt Rhodes
Zaxwerks, Inc.
Richard Brooker
on Oct 25, 2006 at 6:41:07 pm
Thank you Matt for fixing this for me (offlist)!
Richard
Jon Okerstrom
on Oct 26, 2006 at 1:35:10 am
Hi Richard and Matt..
Just curious... was it a rendering error, a model problem or something else... reversed normals?
Jon
Richard Brooker
on Oct 26, 2006 at 2:47:21 am
Hello Jon.
It was something about "rendering optimization code that didn't look too good at these levels."
I should let Matt answer this one, it's way over my head.
It got fixed and I'm a happy camper!
Richard
