3D flag and masks in AE7
COW Forums : Zaxwerks
Philippe Gosselin
on Oct 16, 2006 at 3:16:08 pm
Hi all,
I tried to search this topic but couldn't find anything, strange because I am sure this question must've been asked a 1000 times before. Anyway here we go.
It's quite simple. I'd like to apply the 3D flag plugin to a mask and not the entire layer. No matter what i do it doesn't seem to work.
Here is a pic of the mask
http://img273.imageshack.us/img273/8702/masking2hc8.jpg
Is that feasable anyway?.
Maybe another plugin would do the trick, if so which one ?
Phil
Jon Okerstrom
Re: 3D flag and masks in AE7
on Oct 16, 2006 at 6:11:25 pm
Hi Philippe,
The solution depends in what you're trying to accomplish with the mask.
Having said that, my hunch is that you'll get what you want by putting the mask into a precomp and moving the attributes for it into the precomp.
Then select the precomp for the color layer "get size from" color layer pop-up in the flag plug-in. You can change what's seen in the mask by changing what's in the precomp.
Does this help?
Jon
Philippe Gosselin
on Oct 16, 2006 at 7:02:36 pm
Hi Jon,
OF COURSE !!!!
I am really green with AE, I did one Total training a couple of weeks ago and I am still learning along the way. Strangely, a couple of days ago I actually had the reflex of thinking about nesting a comp so that the effect would affect the entire animation.
I don't know why I didn't have the same reflex here.
That did the trick Jon. Thank you for your time
Phil
