Boolean?
COW Forums : Zaxwerks
Adam Duguay
Boolean?
on Oct 10, 2006 at 1:16:31 am
Is there a way that I can do a Boolean in Pro Animator?
I have an illostrator file with two curves in it. I want the outside curve to difine the Outside edge, and the inside curve to define the hole in the object.
Hope this makes sens.
A
Jon Okerstrom
Re: Boolean?
on Oct 10, 2006 at 1:21:21 am
Adam,
Invigorator doesn't do boolean functions. However, you so have some options. If you make a compound path, you can cut holes in shapes.
If you want to make a hole in the face or edge of an object, you can create a transparency map and apply it to that surface.
Does this help?
Jon
