proanimator 90 % rotate
COW Forums : Zaxwerks
daveyg
on Oct 7, 2006 at 10:20:55 pm
hey all I am working with proanimator and want to do a 90 degree rotation. how do I change the anchor point so that the text doesnt rotate in center but at the bottom.
Imagine the text being on the floor flat and then because of a lightning pass they rotate off the ground to reveal to logo. They would rotate in the middle
Jon Okerstrom
Re: proanimator 90 % rotate
on Oct 8, 2006 at 2:13:47 pm
Hi Daveyg,
My first thought was maybe you could add an object immediately below the text, the same height as the tallest letter and make that object invisible, either by 100% transparent materials or by selecting the object and clicking the visibility box.Create a second pose then rotate all of the objects on their common center.
The common vertical center should be at the bottom of the text.
Jon
