Invigorator won't see my text
COW Forums : Zaxwerks
Mark Volzer
on Oct 7, 2006 at 4:38:10 am
Ok so I'm animating a logo and using Invigorator, but it won't recognize my text. It says there are no usable paths, but I have already converted the text to paths (create outlines) in Illustrator. Is there a compatibility problem between Illustrator CS, AE 6.5 and Invigorator?
Jon Okerstrom
Re: Invigorator won't see my text
on Oct 7, 2006 at 12:38:00 pm
Mark,
My first guess is that you need to resave the Illustrator (text converted to outlines) file in Illustrator format, but be sure the "use compression" check box is unchecked.
Jon
Mark Volzer
on Oct 9, 2006 at 6:33:42 am
Still doesn't see it. I know that invigorator like files in illustrator 8 (or at least it used to) could that be the problem?
Jon Okerstrom
on Oct 10, 2006 at 12:02:31 am
Mark,
What version of Invigorator are you using? Older versions do require legacy Illustrator files.
Send me your file if you want. jokerstrom1 (at) mac.com.
Jon
