Half ring
COW Forums : Zaxwerks
doug
Half ring
by
on Sep 28, 2006 at 11:10:46 pm
Hello,
I am trying to make half a ring. I have a half circle path with two anchor points a stroke of 1 and no fill. The problem is, when I import into zaxwerks the half circle is there but now there is a line connecting the two anchor points. What do i need to do in Illustrator?
Thanks in advance
Doug
doug
Re: Half ring
by
on Sep 28, 2006 at 11:50:02 pm
I think i got it
promoboy
Re: Half ring
on Sep 28, 2006 at 11:50:54 pm
What did you do to get it to work?
Mike.
Jon Okerstrom
Re: Half ring
on Sep 29, 2006 at 1:24:31 am
Hi Mike,
Invigorator will attempt to close open paths. One solution is to outline the stroke in Illustrator. This creates a filled solid object representing the half circle. Another alternative would be to create a transparency map to make half of the circle shape invisible.
Jon
