Object Style Library from Invigorator classic plugin for AE to ProAnimator plugin
COW Forums : Zaxwerks
N12gfx
on Sep 27, 2006 at 5:59:05 pm
Im trying to save my Object Style Library from Invigorator classic plugin for AE to be used in ProAnimator plugin (AE)....any suggestions....I am able to save the library but i cannot load it into ProAnimator
Jon Okerstrom
Re: Object Style Library from Invigorator classic plugin for AE to ProAnimator plugin
on Sep 28, 2006 at 12:31:23 am
Hi N12gfx,
The answer depends on which version of Classic you're running. I believe the file format for libraries has been changed between version 3.x and 4.x. The libraries in Invigorator 4.0x and beyond were rewritten to keep the file size down.
This may be a case where you need to upgrade Classic to get the compatibility back. Of course, you can simply make a note of the settings you want to replicate and build new materials in the ProAnimator Library.
Does this help?
Jon
