Need to change output size
COW Forums : Zaxwerks
dm
by
on Sep 26, 2006 at 5:19:25 pm
Just rendered my first 3D text animation (rendered quicktime movie as animation millions colors+) and imported into fcp 5, only problem is the animation is not 720x486 it is smaller. I need to blow it up by 15% to fit to edge safe and that degrades the quality of the text. How can I increase the
scene size in zaxwerks.
Thanks for the help...program is cool.
DM
Jon Okerstrom
Re: Need to change output size
on Sep 26, 2006 at 10:06:39 pm
Hi DM,
You're right not to try to resize an animation that's rendered at the wrong resolution. Better to change the resolution size in ProAnimator or Invigorator/AE and crank out the movie at the correct resolution.
Click the camera icon below the scene preview window. Choose the resolution preset you want or enter your own numbers and choose the proper pixel aspet ratio then re-render your movie.
Does this help?
Jon
