how to fade in and out--poses in ProAnimator
COW Forums : Zaxwerks
BillM1080
on Sep 21, 2006 at 2:51:11 am
some of the presets have poses with fade-ins and fade-outs, but I'm durned if I can figure out how. I've just gone though the ProAnimator manual table of contents and index twice--still nothing. any help? is there a button I'm staring at but still not seeing?
Jon Okerstrom
Re: how to fade in and out--poses in ProAnimator
on Sep 21, 2006 at 3:12:47 am
Hi Bill,
Yes, you've probably stared at it, and there's a little bit of irony in your comment. It's the eyeball tab under pose presets. Click that, then you can choose to fade off or fade on the objects in that track during the selected pose.
Use the slider below it to adjust the cascade effect. You should see some great results now!
Jon
BillM1080
on Sep 21, 2006 at 3:39:06 am
Yep, there it is. It's probably mentioned in the manual, just ought to be in the index too.
Thanks for the fast answer, Jon -- I have time to add some fades and re-render before the end of this session!
