C4D import solved, might help you too!
COW Forums : Zaxwerks
b3nn3y
on Sep 15, 2006 at 12:19:56 am
I've been using the latest version of C4D, 9.6. And for a week I've been trying to import models into zax. It's been a real brain teaser for me but here's the solution if anybody needs it:
In C4D under Edit-Preferences go to Import/Export and then DXF Export. Then select the Export Type to 3D Face.
This is the one setting under the one format that zax will take from C4D 9.6, i hope this helps.
