Planets
COW Forums : Zaxwerks
ccsmith7
Planets
on Aug 26, 2006 at 1:18:29 am
I would like to try to make the Planets Saturn and Uranus in Invogorator Pro for AE.The planets are no problem. I am having a problem of making the rings. I do not know how to make them. Any help would be grateful. Thanks in advance
Serge
Re: Planets
on Aug 26, 2006 at 1:53:16 am
-In IL create a circle with a hole. This will be your ring.
-In PS or ae create a square map. 1000 X 1000 for instance and make sure that it's tillable.
-In Invigorator place the circle object around your planet, set the depth to (0)and map the square map to it.
Let us know if you need more help.
Salut.
Serge
Jon Okerstrom
Re: Planets
on Aug 26, 2006 at 1:58:34 am
Another way:
Create the rings image on a square Photoshop document and save it with an alpha channel. Apply that image to a square plane primative in Invigorator.
The illusion works unless you plan on getting really close to the rings and flying through them like NASA animations. You would have to use a very high resolution image with the little chunks of material.
Jon
Serge
Re: Planets
on Aug 26, 2006 at 2:22:41 am
What the heck! You are such a great guy. So here is a project:
http://www.nyc-visual.com/Saturn.sit
Notice the way I created the map.
Salut.
Serge
Julian06
Re:Project link is broken
on Aug 27, 2006 at 8:15:54 am
Hi
@serge
I'd like to have a look at your planet project but your link doesn't work !I always get an error message
Serge
Re: Re:Project link is broken
on Aug 27, 2006 at 3:28:56 pm
Sorry about that. I asked someone at the office to upload the example again.
Let me know if you need something else.
Salut.
Serge
ccsmith7
Re: Planets
on Aug 28, 2006 at 10:00:55 pm
WoW! Thanks a million! You do incredible work. Remember I still owe you a drink(s)
Serge
Re: Planets
on Aug 28, 2006 at 10:26:51 pm
Actually, I owe you the drinks:-)
I have to pack and fly to Florida chasing the upcoming hurricane. I will get in touch with you once I am back.
Salut.
Serge
