Saparate blend on a individual layer
COW Forums : Zaxwerks
PRgraphist
on Jul 26, 2006 at 12:30:51 am
Hoe I can separate the in-between shapes of a blended shapes on a individual layers, to use a cycling layer in invigorator
Image is Everyting
Jon Okerstrom
Re: Saparate blend on a individual layer
on Jul 26, 2006 at 12:43:01 am
It depends on which version of Illustrator you're using.
Try: Object>expand, followed by Object>ungroup.
Jon
PRgraphist
on Jul 26, 2006 at 2:29:11 am
I use CS2 Version. I expand and ungroup but all the in-between shapes still on one single layer. I separate all shapes manually, but with this method is easy to make a mistake and the animation not correctly. anybody know a way to automatically make one layer for each in-between shapes.....sorry I a newbee in illustrator
Image is Everyting
Jon Okerstrom
on Jul 26, 2006 at 3:27:08 am
Hi PRgraphist,
Check out the layers window and release to layers (sequence.) That should do it and save you a ton of time if you have a complicated blend going on.
Jon
PRgraphist
on Jul 26, 2006 at 5:42:28 pm
OK,, This allow to separate all the items in sub-layers.. I need all the shapes in an layer itself not under other layer....
Thanks anyway....
Image is Everyting
Jon Okerstrom
on Jul 26, 2006 at 6:13:09 pm
Sublayers do work as layer cyclying layers in Invigorator.
Jon
PRgraphist
on Jul 27, 2006 at 9:54:03 pm
I try to open a cycling layer, but invig not "see" anything and do not give any error message or something like this just keep the scene as a empty scene
Image is Everyting
