Open vs Closed Path
COW Forums : Zaxwerks
Hamboy
Open vs Closed Path
on Jul 21, 2006 at 6:12:18 pm
I am trying to create an open path in Illustrator (CS2) to export to Invigorator in AE. I save an open path as Illustrator 8, open it in Invigorator, and the the start and end of the path are connected by a straight line. I am trying for a filstrip effect like Serge had for a tutorial, but I can't create an open path. How is this done?
Serge
Re: Open vs Closed Path
on Jul 21, 2006 at 9:39:04 pm
Hi Hamboy,
- Create an open path using the Pen Tool.
- Select your path & got to Object>Path>Outline Stroke. This will close your path.
- Make sure, now that your path is diagonal so the mapping starts at one end of your object (The lower left)
- In Invigorator switch the front & Back faces off & increase the Depth value.
- Using the layer mapping technique, create a transparency map that is half-white/ half-black or alpha so you can eliminate the backside of your filmstrip.
Salut.
Serge
