banding in gradients
COW Forums : Zaxwerks
lensflare1
on Jun 28, 2006 at 10:58:39 am
Hi there.
Can invig/proanimator create smooth (non banded) gradients.
I have been flying objects in up close, and you can see the gradients...
Is it an 8, 16 or float point renderer
Cheers
Lensflare
Jon Okerstrom
Re: banding in gradients
on Jun 28, 2006 at 12:57:48 pm
Hi Lensflare,
I haven't run into the banding issue with either app, but I suppose it's possible with certain gradients, if the rendering engine is 8 bit. Perhaps Matt will jump in with the tech spec for you.
The cartoon color rendering option does create banding - a posterization effect - on purpose.
Jon
Matt Rhodes
on Jun 28, 2006 at 3:35:08 pm
Hi Lensflare.
The current Invigorator/ProAnimator renderer outputs in 8-bit (even though everything internal is done in floating point).
You may see banding in certain circumstances (when the color variation across a large portion of the screen is minimal),
but most users won't see any.
Now that After Effects supports floating bit output, we're looking into higher-bit output.
Stay tuned. And let us know if you have any other questions.
And, as always, feel free to download a demo of the product to see if it does what you want.
Matt Rhodes
Zaxwerks, Inc.
lensflare1
on Jun 29, 2006 at 4:23:01 am
Thanks for that. Float would be great.
Cheers
Lensflare
"That Camel had it coming I tells ya...."
