Invig to ProAnim
COW Forums : Zaxwerks
Curtis
Invig to ProAnim
on Jun 9, 2006 at 8:17:50 pm
Is there a method for moving InvigPro scenes into ProAnimator?
Curtis
Curtis
Re: Invig to ProAnim
on Jun 9, 2006 at 8:33:04 pm
Or can objects be moved from Invig to PA?
Jon Okerstrom
on Jun 10, 2006 at 12:40:50 am
Hi Curtis,
You can move objects from Invigorator to ProAnimator and visa versa. In PA, you can use the object pop-up menu or object pull down menu>export 3D objects>choose all, selected or visible>use zxo format.
In invigorator, you can do the same using the object pop-up menu.
Then, in the other ap, use the object pop-up to import 3d object.
Does this help?
Jon
